mcnitzken
Jul 31, 2021Guide
ORBI RBS750 no longer stable in v4.6.3.7 - Possible downgrade assistance
Hi, was hoping I might get some help here as after calling Netgear I got met with "Everything appears to be fine", despite the fact the satellite no longer works. I have an Orbi 752 set with 1 RB...
- Jul 31, 2021
I'd actually tried most of these options as I'd seen some of the previous posts and started trying everything out of desperation. I've sort of reached a point of a usable point, although probably not the optimal situation.
the router seems to be stuck on the v4 firmware, but I was able to downgrade both satellites to v3.18 and after a factory reset they connected up and are working normally. So basically I have two different firmwares running, but my speeds are actual normal and the coverage is stable now.
So, while definitely not a perfect option for anyone else stuck with a non working system after v4 you can
1. Go to the RBS750 support page and download the latest v3 firmware (I used the v3.18)
2. Plug into each satellite with Ethernet and manually load the downgrade and run it
3. Factory reset the router and set it up the satellites and internet
4. On one of the satellites I needed to do a factory reset on the satellite as it had a different login password after the downgrade and was showing solid purple.
5. I also set static ips for both of my satellitesIts not 100% perfect as I occasionally see out of sync messages in the logs, but the satellites themselves powered on and connected as blue and after a minute or two the light went out and they both have ~30 devices hooked up to them now with the router having another 40. Everything is getting decent speed tests and is able to work on the network. It's been stable for over 2 hours now, so I'm going to consider this a win as I had at most 5 mins of stability for the last 24 hours.
I'll probably leave my network in this split firmware state and hope that netgear can release some updated firmware that doesn't nuke the satellites soon!
Sep 07, 2021Guru - Experienced User
Mines working well on v4 after this transpired:
crawrj
Sep 07, 2021Guide
I saw that and was going to try the same on the 750 just to see. Have you heard of anyone having success with that on the 750 by chance? I have asked for the Beta firmware but am waiting on a reply.
- FURRYe38Sep 07, 2021Guru - Experienced User
Not that I'm aware of or if it has, not sure if anyone responded.
Was certainly a odd event on mine since I had been using v4 in router mode and hadn't seen any problems up until I factory reset using the ERASE button and encountered those problems and reproduced the boot loop issue on the RBS. Leaving my system OFF until the next day cleared it up. I don't believe 24hours unplugged is needed. It was just the time frame that I stopped trying to figure out the problem and left it until the next day after I got home from work. Then started working for me. Crazy for sure. :smileyembarrassed:
Something to try while you wait for the Beta.
