Brandon1972
Aug 27, 2022Aspirant
Orbi RBS750 will not appear on Network Map
I am having a very frustrating issue. I have an Orbi RBR750 and 2 RBS750 satellites. The satellites just stopped working a few weeks ago. Before doing any research, I updated the router to Firmwar...
Brandon1972
I tried that sequence...the satellite lights up blue (as if it should be connected) but does not appear as a connected device on the web site or the App network map. Therefore, I cannot get the IP address.
Aug 27, 2022Guru - Experienced User
When its hardwired in, if you connect a pc/laptop to the satellite, are you able to use the internet?
Just curious if its working and the maps taking a while to load.
When hardwired in, you can try its default ip address of 192.168.1.250
