mrb392
Oct 13, 2023Aspirant
Orbi RBS760 satellites not sharing network password from RBR750 / RBS750
I had an Orbi #RBR750 Router and 1 #RBS750 satellite set up with no problems with the same SSID and password combo being shared across the 2 units in the network I have since added a further 2 x ...
Oct 13, 2023Guru - Experienced User
have you tried hardwiring them into the router to sync them?
Try factory resetting them and hardwiring them in for setup.
- mrb392Oct 14, 2023Aspirant
I have one hardwired already, but I set it up wirelessly and then moved it and hardwired it in.
It behaves the same. It gives out great WiFi but you have to log in to that satellite specifically.
I will try syncing via Ethernet and see if that helps.
Thanks
- FURRYe38Oct 16, 2023Guru - Experienced User
I'd return the 760 RBS. Find something more compatible.
