mrb392
Oct 13, 2023Aspirant
Orbi RBS760 satellites not sharing network password from RBR750 / RBS750
I had an Orbi #RBR750 Router and 1 #RBS750 satellite set up with no problems with the same SSID and password combo being shared across the 2 units in the network I have since added a further 2 x ...
Oct 13, 2023Guru - Experienced User
Possible that the RBS760 FW v6 is not compatible with v7 FW for the 750 series yet. Something NG will have to turn up for the 760 series.
CrimpOn
I'll believe it when that big red X on the compatibility chart is replaced with a check mark.
- FURRYe38Oct 13, 2023Guru - Experienced User
Ya, probably will need to return the RBS760s and find some more compatible RBS. I keep a eye out on amazon and goodwill.
- CrimpOnOct 13, 2023Guru - Experienced User
People have reported satellites having different behavior when wired to the router rather than using the WiFi backhaul.
Would it be a big chore to temporarily locate one of the 760 satellites in the same room as the router, connect them with an Ethernet cable, and observe what the satellite WiFi does?
(I know using wired backhaul is simply not an option for many users [including myself]. The question is more intellectual curiosity than practicality.)
That and the differences between v6 and v7 FW would be the other factor. Wifi changed in v7. So would make other FW versions not compatible.
- mrb392Oct 14, 2023Aspirant
Yes, I think this is the case.
Frustratingly I think I clicked the wrong model when ordering on Amazon as I had checked the compatibility when researching which one I needed.
