mrb392
Oct 13, 2023Aspirant
Orbi RBS760 satellites not sharing network password from RBR750 / RBS750
I had an Orbi #RBR750 Router and 1 #RBS750 satellite set up with no problems with the same SSID and password combo being shared across the 2 units in the network I have since added a further 2 x ...
Oct 13, 2023Guru - Experienced User
What FW versions are loaded on the 750 series and 750 series units?
I have since added a further 2 x #RBS760 satellites to my set-up.
They have connected to the network with no problem and are showing in the network map, however, they are not sharing the SSID and Password the original router and satellite use.
You have to log on to each #RBS750 satellite individually with the local name and password detailed on each unit, and you get great wifi once logged in locally.
I have made sure I have the latest software updates and have tried disconnecting, factory resetting, and reconnecting as suggested in other posts but I have had no luck.
Are there any advanced settings I need to administer to make the 760 Satellites share SSID and PW with the 750 Router and satellite?
Thank you
mrb392
Oct 14, 2023Aspirant
Hi, Firmware Versions for each model below.
RBR750 = V4.6.14.3
RBS750 = V4.6.14.3
RBS760 = V6.3.4.12
Thank you.
