TeresaA0627's avatar
TeresaA0627
Follower
Aug 16, 2024
Orbi RBS760
I have purchased an Add-on Satellite for my RBS760 Tri-band Mesh Wifi System.  It only came with US & EU power adaptor and I need the plug for Australia.  Can I purchase a compatible power adaptor because i don't want to have to send back the whole thing.
  • Amazon carries power adapters compatible with most Orbi units.  Is there Amazon in Australia?
    The key is the output must be 12V, 2.5 amp with the correct size plug.
    Australia is a 220-240v @ 50Hz standard. Most of Europe is also 220v.  If the power adapter shipped with the unit says it is compatible with 220-240v, there is probably a travel adapter that will allow the existing adapter to plug into your outlets.
1 Reply
  • CrimpOn's avatar
    CrimpOn
