Pdiggs
Jan 25, 2021Aspirant
ORBI RBS850 Blinking White and will not connect to RBR850 Router
Please Help. I had both satelites working fine and now 1 satelite will not connect. It just blinks white. I have factory reset to blinking amber and it still blinks white. I've tried to hardwire my l...
Pdiggs
Jan 27, 2021Aspirant
Thanks I tried to follow this. But it's confusing- what is the point of connecting to the first Satellite and then to the dead one?
Jan 27, 2021Guru - Experienced User
Sorry I should have not mentioned the 1st satellite, rather, Connec to the one satellite giving you problems.
- PdiggsJan 28, 2021Aspirant
thanks, I've tried multiple times, reset the satelite, connect via ethernet to laptop, reset IP address, and wan adapter, restarted laptop. The RBS850 satellite won't assign an ip. It actually just keeps blinking white. After the hard reset it turns amber, then blinks amber, then blinks white and that's all it does. Makes for a really annoying night light! I guess now it's onto Netgear customer service to negotiate a replacement. That should be fun since it was bought from Amazon as a part of a package with two satelites. The system is amazing- when it was working!
- FURRYe38Jan 28, 2021Guru - Experienced User
How long do you wait on the RBS to give an IP address to the connected LT after you resetting? Usually takes about 5-6 minutes.
Ya, get in contact with NG support and ask about an RMA.- PdiggsJan 28, 2021Aspirant
Thanks! I have waited up to 10 minutes. I'll try one more time tonight, otherwise it's either a cool paperweight or Customer service will hook me up
