Gman001
Aug 25, 2024Follower
Orbi RBS850 Satellite - Not Rebroadcasting 2.4 GHz
The satellites only seems to rebroadcast 5ghz. How do I also rebroadcast 2.4ghz??? Some of my equipment only uses 2.4. Thanks!
Aug 26, 2024Guru - Experienced User
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
Swap RBS location if you have two RBS?
