_tus_
Oct 20, 2020Tutor
ORBI RBS850 Satellite restarts several times a day
Hi, I'm using a RBK853 kit, upgraded to V3.2.16.6_1.4.4 version for all parts. RBR850 is configured in AP mode, both RBS850 satellites and RBR850 router are in DHCP mode. One RBS850 satellit...
Oct 20, 2020Guru - Experienced User
Are you using a Dynamic or Static IP address configuration on the RBR in AP mode?
Has a power off for 1 minute then back on been performed since last update?
- _tus_Oct 20, 2020Tutor
Hi,
Router is my ISP one : Sagem Livebox 3 Pro for Orange France ISP.
RBR850 gets its fixed IP from DHCP (mandatory for Livebox DNS activation), same for the 2 satellites.
No more than a dozen of Wifi network nearby.
None with more than -70dBm SNR under wifi analyzer when Orbi's one are over -44dBM (I'm in a separate House).
Between 2 restarts, wireless / wired connection through the RBS850 is reliable which does not seems to indicate an interference issue.
The RBS850 which restarts often has been power-off for more than a days without change in its behavior.
The RBR850 and the second RBS850 were not powered-off more than the time they need to restart.
- FURRYe38Oct 20, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
I presume any wiif radios on the ISP modem are turned OFF fully?
- _tus_Oct 21, 2020Tutor
Manually set to Chanel 11 for 2.4GHz. ISP router has wifi disabled.
So far no restart observed on the satellites (it also spent the whole night unplugged).
Let see if this solves my concern.
In the meantime, any clue on how fixing the 2.4GHz channel could have a influence on the unexpected restart of the system?
Guillaume
