_tus_
Oct 20, 2020Tutor
ORBI RBS850 Satellite restarts several times a day
Hi, I'm using a RBK853 kit, upgraded to V3.2.16.6_1.4.4 version for all parts. RBR850 is configured in AP mode, both RBS850 satellites and RBR850 router are in DHCP mode. One RBS850 satellit...
Jan 27, 2021Guru - Experienced User
You might send them a direct PM as well.
Good Luck.
_tus_
Apr 15, 2021Tutor
Hello
I forgot to post a follow-up.
After redoing the same test with the netgear support, RMA was granted and the faulty RBS was replaced a dozen of days ago.
So far, it works like a charm.
Many thanks to FURRYe38
- FURRYe38Apr 15, 2021Guru - Experienced User
Glad you got a replacement.
Enjoy. :smileywink:
