rbgb42
Apr 03, 2023Aspirant
Orbi RBS850 satellite with ASUS ZenWiFi Pro XT12 router
Good day Is it possible to connect the RBS850 satellites with an ASUS ZenWiFi Pro XT12 router to extend coverage ? Is this suported? I have 4 x RBS850 satellites.My RBR850 router appears to be f...
rbgb42
Awesome, thanks so much for the quick response.
Apr 03, 2023Guru - Experienced User
Pretty sure its not. Orbi's aren't even that compatible within their own eco-system so doubtful they'll work well with someone else's.
Here's the orbi compatibility chart.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
- CrimpOnApr 03, 2023Guru - Experienced User
Not a chance in Hell. No Way.
