alvine
Oct 21, 2024Tutor
Orbi RBS850 stuck on boot loop
Hi Netgear Community! This is my first post and looking for a possible way to recovery my RBS 850 stuck on boot-loop. I already already tried a usb ttl converted to read the output but no luck. ...
alvine
Oct 21, 2024Tutor
Updates..
Putty
Client starts...[Listening] for ADVERTISE...
NMRP CONFIGING
Recv FW-UP option
No ST-UP option
NMRP WAITING FOR UPLOAD FIRMWARE or STRING TABLES!
start nmrp , change pwr led to solid amber
ipq807x_eth_halt: done
eth0 PHY0 Down Speed :10 Half duplex
eth0 PHY1 Down Speed :10 Half duplex
eth0 PHY2 Down Speed :10 Half duplex
eth0 PHY3 up Speed :10 Full duplex
eth0 PHY4 Down Speed :10 Half duplex
10M speed not supported
ipq807x_eth_init: done
TftpServerStart()
Listening on Port : 69, IP Address: 10.164.183.253 ...
waiting nmrp server to upload firmware!
Tstart nmrp , change pwr led to solid amber
TftpServerStart()
Rcv:
T T T T T T T T T T T T T T T T
D:\Download\nmrpflash-0.9.24-win32>nmrpflash.exe -i net3 -f RBS850-V7.2.6.31.chk
Advertising NMRP server on net3 ... |
Received configuration request from 08:36:c9:e0:d5:01.
Sending configuration: 10.164.183.253/24.
Received upload request: filename 'firmware'.
Uploading RBS850-V7.2.6.31.chk ... Timeout while waiting for ACK(1).
- FURRYe38Oct 21, 2024Guru - Experienced User
Does a 30-30-30 reset change anything?
- alvineOct 21, 2024Tutor
Hi appreciate for your reponse but 30-30-30 does not do anything.
It seems that the LAN is not up hence cannot transmit the packets.
Latest updates
eth0 PHY0 up Speed :10 Full duplex
eth0 PHY3 Down Speed :10 Half duplex
TftpServerStart()
Listening on Port : 69, IP Address: 10.164.183.253 ...retry tftp_upload count exceeded;
TTTTT
Rcv:retry conf count exceeded;
Client starts...[Listening] for ADVERTISE...TTT
Retry count exceeded; boot the image as usual
ipq807x_eth_halt: doneFirmware recovering from TFTP server is stopped or failed! 😞
ipq807x_eth_halt: donenmrp server is stopped or failed !
D:\nmrpflash-0.9.24-win32>nmrpflash.exe -vvv -i net3 -f RBS850-V3.2.17.12-signed.chk -t 180000 -m 08:36:c9:e0:d5:01
nmrpflash 0.9.24
{0EAAB078-062E-4F23-8993-3562096C5431}: Type=6, Name=Ethernet
Waiting for Ethernet connection (Ctrl-C to skip).
Adding 10.164.183.252 to interface net3.
Using remote filename 'firmware'.
Uploading RBS850-V3.2.17.12-signed.chk ... << WRQ(firmware, octet)
Discarding TFTP_UL_REQ packet
>> ACK(0)
<< DATA(1)
<< DATA(1)
<< DATA(1)
<< DATA(1)
<< DATA(1)
Timeout while waiting for ACK(1).- FURRYe38Oct 21, 2024Guru - Experienced User
Ok, looks like the RBS has failed and not recoverable. I'd get it replaced.
