donawalt
Aug 01, 2022Mentor - Experienced User
Orbi RBS850 stuck on solid blue
Today I saw something I never saw before - from early this morning, about 6 am, until 11am, one of my 2 RBS850's showed solid blue the whole time. Everything else on the network looked fine - logs ok, performance ok, etc...just sitting on blue like it does for 5 minutes or so on a restart. I found this is an old problem that may still happen from time to time:
https://community.netgear.com/t5/Orbi/Orbi-satellite-stuck-on-solid-blue/td-p/1349539
I read that the problem seemed to go away with a power cycle, which I did, and it's been fine for about 2 hours now. Also, like others, I had no 2.4GHz devices connected.
(As an aside, I do have a Logitech remote hub about 10 feet from the RBS that connects at 2.4GHz, but it always seems to connect to the RBR850 down in the basement - I have assumed that the signal is strong enough there for a 2.4GHz device that it never needed to switch to the closer satellite, and it works fine, so I never worried about it.)
Hopefully the solid blue light doesn't come back, it's really annoying in a dining room to see that bright blue light! I am posting as well so people know this problem is still in the firmware somewhere...
Did you try to log into the RBS web page then see if the front LED turned OFF?
- donawaltMentor - Experienced User
I am pretty sure I did log into all the devices' web pages (RBR and 2 RBR's), just to see if I saw anything unusual. That didn't turn off the blue light unless I was supposed to do something once there.
Keep an eye on it. May have been some fluke in the system.
