ErikSFRFR
Dec 27, 2023Aspirant
Orbi RBS850 VPN Client Devices Cannot Access LAN
I'm struggling to setup my VPN such that I can access the devices on my LAN. I'm using OpenVPN and No-IP for my dynamic DNS. I have downloaded the OpenVPN configuration to my phone with the sett...
CrimpOn
Dec 27, 2023Guru - Experienced User
It would help to know how the phone is attempting to access other devices on the LAN.
Because smartphone VPN connections are tun (Layer 3 "tunnel") rather than tap (Layer 2 "tapped into the subnet") communications that rely on LAN broadcasts may not be successful, whereas communications that specifically provide the target IP address will.
https://en.wikipedia.org/wiki/TUN/TAP
What application is being used on the smartphone?
iPhone or Android?
- ErikSFRFRDec 27, 2023Aspirant
Thanks CrimpOn I'm using an iPhone.
I have an Amcrest camera and an Aquarium controller (GHL Profilux) on my local network. Both are assigned to a static IP address by the router. I'm not sure how to tell exactly how the respective apps are accessing the devices.
Interestingly for the Camera - I can get a response by putting the IP address directly into the browser. It isn't possible to access the feed that way (that functionality is no longer supported), but it does bring up a log in prompt - something that does not happen if you are both off the network and not on VPN. Going through the app though, I cannot access the feed as I can when I'm on the local wifi network. The app for the aquarium controller requires entering the IP address in order to make a local connection, but I'm unclear how to determine how the phone is accessing the device.
I run into a similar issue on my Mac when I VPN where I cannot access these devices. I also cannot see the other macs on the network under "network" which I can when I am on the local network.
I had VPN setup on the Orbi previously and was at that time able to access the devices. I'm not entirely sure what has changed. I accidentally let my No-IP account lapse and when I got it reinstated I set up my VPN again and it hasn't worked right since.
