Naafets88
Aug 25, 2024Aspirant
Orbi RBS850
Hi All, I own a RBR850 with 2 sattelites for 2 years and works amazing. Yesterday I bought a 3th sattelite to cover a bigger area (Garden for my lawnrobot) and been trying since then to add it t...
CrimpOn
Aug 25, 2024Guru - Experienced User
Naafets88 wrote:
After a factory reset I'm not able to login to the router itself while it's wired to a pc while all other routers were switched off, after that I did a 30-30-30 reset and also no luck.
After a factory reset, a web browser running on a PC that is wired directly to the RBR850 router should open the configuration screen when connected.
Are you using http://orbilogin.net or an IP address to connect to the router?
- Naafets88Aug 25, 2024AspirantI connected the RBS850 directly to the desktop, but was not able to connect it through the IP-address.
I switched off my complete network while resetting and connecting.- CrimpOnAug 25, 2024Guru - Experienced User
How did you choose the IP address to use in the web browser.
- Naafets88Aug 25, 2024AspirantI saw people with similar issues and they used a certain IP address to access the router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/I-am-unable-to-connect-my-replacement-RBS850-to-my-network/m-p/2363584
