Naafets88
Aug 25, 2024Aspirant
Orbi RBS850
Hi All, I own a RBR850 with 2 sattelites for 2 years and works amazing. Yesterday I bought a 3th sattelite to cover a bigger area (Garden for my lawnrobot) and been trying since then to add it t...
Aug 31, 2024Guru - Experienced User
What browser are you using? Try Firefox or Opera. Be sure to clear out all browser caches.
What IP address did you get on the PC from the RBS?
Naafets88
Sep 01, 2024Aspirant
I did it first in Google Chrome, Internet explorer and now firefox, but again no luck
IP is 169.254.212.149
- FURRYe38Sep 01, 2024Guru - Experienced User
Can try setting a static IP address configuration on your wired PC to 192.168.10.49 and 255.255.255.0. No gateway is needed. Then try 192.168.10.250 after about 5 minutes of resetting the RBS reset button for 15 seconds then release.
- Naafets88Sep 08, 2024Aspirant
Tried it 3 times and no luck, I honestly don't know what to do anymore
I tried to add the router through the website and during adding I was able to find it.
Got the notification Pairing Successfull and on the satellite I have a solid blue light now, but it doesn't show up in the sattelites list?
What am I doing wrong?
- FURRYe38Sep 12, 2024Guru - Experienced User
So it has never showed up in on the RBRs web page at all?
- Naafets88Sep 13, 2024Aspirant
Correct! I was not able to link it since the beginning.
It was an "add-on" router I bought.
Trying to link it through Chrome
