lmeyler
Feb 22, 2025Aspirant
Orbi RBSE960 Satelite ethernet NIC randomly stop working while wifi from Satelite continues to work
Bought this system in May 2024 and all worked well for months. But for last 2+ months, my Orbi RBSE960 Satelite ethernet randomly stops working. Device wifi connections to the satelite connect fin...
- Mar 07, 2025
I read on another reply to leave the satellite device off for an hour and then power.
No idea why, but after months of issues, this approach worked. Have been up and running for 1 week+ without issue.
Thanks for the reply.
Feb 22, 2025Guru - Experienced User
Something to try. v.31 has many post about odd issues. v.21 is most stable to date. You'll need to factory reset the system and setup from scratch after the RBS is downgraded first, then the RBR lastly.
lmeyler
Mar 07, 2025Aspirant
