AlexP37
Dec 03, 2024Aspirant
Orbi RBSE960 Satellite Issue
Hi, I have an Orbi RBRE960/RBSE960 system with one router + 2 satellites (both satellites with ethernet wired connection to the router). One Satellite is working fine, however the other is not. I...
Dec 04, 2024Guru - Experienced User
is the backhaul directly connected to the router? Running through a switch? running through a gateway device?
- AlexP37Dec 04, 2024AspirantDirectly. Same as other satellite
- plemansDec 04, 2024Guru - Experienced User
try taking that satellite, factory reset it, and hardwire it to the main unit with a different cable.
- AlexP37Dec 04, 2024AspirantHave done that…
Unfortunately didn’t fix anything
- FURRYe38Dec 04, 2024Guru - Experienced User
Does swapping RBS with each other follow the one RBS or problem remains at the one remote location?
- AlexP37Dec 04, 2024AspirantFollows the RBS
