vsogekr9's avatar
vsogekr9
Orbi RGR 750 - Keeps Dropping and Reconnecting
Hi everyone, as the title says I have an Orbi RGR750 with 2 satellites and I notice that my devices keep dropping and reconnecting. I'm assuming that since it's a mesh network they are bouncing between 2.4 to 5.2. I was wondering if there is anything I can check or do to stop this from happening?
1 Reply
  • FURRYe38's avatar
    Do front LEDs turn PINK when then happens on the RBR or RBS?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    What channel configurations are currently set on the router?
    Has a power off for 1 minute then back ON with the ISP modem and router and RBS been performed?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    https://www.reddit.com/r/NETGEAR/comments/1ehq2ft/orbi_rgr_750_keeps_dropping_and_reconnecting
