bensjb0618
May 02, 2023Follower
Orbi Robust Smart Home Wi-Fi Tri-band Mesh Wi-Fi 6 System will not connect to provider’s modem
Will not connect to provider’s modem
May 02, 2023Guru - Experienced User
Not much to go off of.
What Orbi system model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
