katiejim1214
Nov 28, 2023Guide
Orbi Router + Schlage Encode Smart Lock
Hi Everyone, I have an Orbi AX5400 Tri-Band Wifi 6 Router (RBR760) and Schlage Encode smart locks on our home. The locks CONSTANTLY disconnect from Wifi and it is incredibly frustrating. I've tr...
CrimpOn
Nov 28, 2023Guru - Experienced User
Which specific Schlage lock? (They have SO many.)
Generally, Internet of Things (IoT) devices have WiFi radios that detect only 2.4G channels. They are totally unaware of and cannot be affected by other radio signals (5G WiFi, television, portable phones, AM/FM radio.)
Sometimes door locks are not "in a great location" in terms of WiFi signal. One solution is to install an inexpensive WiFi Extender that will connect to the home WiFi and create a 2.4G WiFi signal specifically for the IoT device. (often under $20 on Amazon). If the extender is located with a clear line of sight to the lock mechanism, it may stay connected more easily.
katiejim1214
Nov 28, 2023Guide
Hello!
Model # BE489WB (https://www.schlage.com/en/home/products/BE489WBCAMFFF.html#)
From what I've researched too, it should only pickup the 2.4G channel too just like you said. I'd say the lock is roughly 5-8 feet from our modem and router. We have Spectrum as our internet provider and use their modem. The other lock is roughly 5-8 feet from one of the Orbi Satellites.
Because the lock is so close to the router, do you think an extender is necessary? I had thought about getting one as a hail-mary because I am willing to try everything at this point. I think there is an outlet right by the front door that it could plug in to and allow for a clear line of sight to the lock.
This home is a short-term rental and guests get their own unique code when they book, but if the lock goes offline our system cannot put the code into the lock and it's a whole annoying thing on our end. I just need the dang lock to stay on wifi all the time. #technology
- CrimpOnNov 28, 2023Guru - Experienced User
Took a while, but it is confirmed:
- How often is "constantly"?
- Do both locks disconnect, or one more than the other?
- What does it take to get the locks to reconnect?
Unless there is something like a solid concrete wall between the Orbi WiFi unit and the lock, then installing a WiFi extender would seem unnecessary. If your smartphone has a WiFi Analyzer app (there are dozens), it would be relatively simple to hold the phone close to the lock and observe the WiFi signal strength of the 2.4G channel.
- katiejim1214Nov 28, 2023Guide
Hi!
It does it at least 3-5 times a week. Sometimes it's one lock. Sometimes it's both. Eventually they just re-connect; sometimes in minutes, sometimes in hours, sometimes in days. Very inconsistent. Yesterday they were both off at the same time all day. Usually they reconnect on their own.
I'll have to look into an analyzer app. There is no other way to distinguish 2.4 vs 5 that I'm aware of based on all my research. I don't think there is a way to set up two separate networks with the Orbi either (like to where you can pick one over the other).
- FURRYe38Nov 28, 2023Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS?
