katiejim1214
Nov 28, 2023Guide
Orbi Router + Schlage Encode Smart Lock
Hi Everyone, I have an Orbi AX5400 Tri-Band Wifi 6 Router (RBR760) and Schlage Encode smart locks on our home. The locks CONSTANTLY disconnect from Wifi and it is incredibly frustrating. I've tr...
Nov 28, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What is the distance between this one device and the RBR and a RBS?
Might post about this in the Schlage support forums if this is the only device having problems with Orbi. Possible Schlage issue with Orbi.
katiejim1214
Nov 28, 2023Guide
Hello!
Here are some answers. 🙂
- What Firmware version is currently loaded: On the lock or on the router?
- What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?: Model E31N2V1 Hitron Docsis 3.1 Voice Internet Cable Modem (it's the one that came from Spectrum)
- Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended: I have whatever came with the modem. I'll have to check and see if it's a CAT6.
- How many RBS are deployed: I'm assuming this means the Orbi Satellite, right? If so, just one Satellite.
- What is the size of your home? Sq Ft: Roughly 1,000
- What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBRand RBS to begin with depending upon building materials when wired or wirelessly connected.: I'd say roughly 30' or so!
- Does this happen with the RBS turned OFF? Not sure on this one. I'd have to check and see!
- Does this happen with both wireless and wired devices? I've only ever noticed it happening with the locks. TV, phones, Ring camera, laptop all work just fine.
- What channel configurations are currently set on the router? Not sure on this. Will have to look next time I'm there (it's a short-term rental). I didn't change anything since I set up the Orbi router via the app.
- What is the distance between this one device and the RBR and a RBS? - It's roughly 5-8' from the router. The other lock (We have 2) is roughly 5-8' from the satellite.
Thank you!!
