Rottikid
Jan 13, 2022Guide
Orbi Router Model #RBR850 WiFi 6 WPA3 Ring cameras, Security System, other Devices can’t connect
When I turn on WPA3 Security and IPV6 my Cameras, Doorbell, FireStick and other devices can't connect to 2.4GHz or 5GHz WiFi. Is there anyway to connect these devices manually to 2.4 and 5G and my de...
- Jan 18, 2022
CrimpOn wrote:
Rottikid wrote:
Is there anyway to tell which devices are connected to 5G and which devices are connected to WiFi 6 AX mode on 5G? Is there a breakout like there is for 2.4G and 5G which tells you which is connected to,what.
An interesting puzzle. 2.4G 802.11b/g/n has maximum data rates:
802.11b - 11mb
802.11g - 54mb
802.11n - 600 (theoretical)
If a 2.4G device is connected at a link rate higher than 54mb, is must be 802.11n (or ax?)
Yes, depends on what the device supports.
Don't forget AC. 80Mhz is 1300Mbps, 160 supports 1733Mpbs
5G 802..11 has similar limits. If the link rate is higher than 866, it must be ax. Actually don't forget AC. 5Ghz AC supports up to 1733Mpbs if 160Mhz is suported on both devices.
The only devices that can be connected with ax must have the capability of ax. That rules out a huge fraction of the devices in most homes.
Not having any myself, I wonder if any devices are capable of displaying ax connection? Depends on there support. Why have some load up WifiSweetSpots app on some mobile devices, can get a ball part speed rate with this app.
Jan 17, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first.
Ask the ISP if you can remove there router from the system and use Orbi router instead.
