Rottikid
Jan 13, 2022Guide
Orbi Router Model #RBR850 WiFi 6 WPA3 Ring cameras, Security System, other Devices can’t connect
When I turn on WPA3 Security and IPV6 my Cameras, Doorbell, FireStick and other devices can't connect to 2.4GHz or 5GHz WiFi. Is there anyway to connect these devices manually to 2.4 and 5G and my de...
- Jan 18, 2022
CrimpOn wrote:
Rottikid wrote:
Is there anyway to tell which devices are connected to 5G and which devices are connected to WiFi 6 AX mode on 5G? Is there a breakout like there is for 2.4G and 5G which tells you which is connected to,what.
An interesting puzzle. 2.4G 802.11b/g/n has maximum data rates:
802.11b - 11mb
802.11g - 54mb
802.11n - 600 (theoretical)
If a 2.4G device is connected at a link rate higher than 54mb, is must be 802.11n (or ax?)
Yes, depends on what the device supports.
Don't forget AC. 80Mhz is 1300Mbps, 160 supports 1733Mpbs
5G 802..11 has similar limits. If the link rate is higher than 866, it must be ax. Actually don't forget AC. 5Ghz AC supports up to 1733Mpbs if 160Mhz is suported on both devices.
The only devices that can be connected with ax must have the capability of ax. That rules out a huge fraction of the devices in most homes.
Not having any myself, I wonder if any devices are capable of displaying ax connection? Depends on there support. Why have some load up WifiSweetSpots app on some mobile devices, can get a ball part speed rate with this app.
CrimpOn
Jan 17, 2022Guru - Experienced User
Rottikid wrote:
The only reason I want to use WPA3 is because it is necessary if I'm going to use WiFi 6.
This is not my understanding. If WPA3 were required any time 802.11ax is enabled, then Netgear would not allow any other choice of security. All of the posts I have seen about the Orbi AX remark that users wish Netgear had provided WPA2/WPA3 mixed security, because the way it is they have to use WPA2 for all their devices that cannot use WPA3. That is, they use (802.11ax) and WPA2.
Rottikid
Jan 17, 2022Guide
CrimpOn,
the only way to use WiFi 6 is to use WPA3.
6GHzIf you open the Orbi app and go to WiFi settings then go to Security method they offer:
None
WPA2-Personal
WPA3-Personal
WPA/WPA2-Personal
At the very bottom it says:
Note: 6GHz WiFi supports only WPA3
NETGEAR hopefully will have a fix shortly. Thanks again for all your help. Does anyone have Netgear's Corporate phone number or a Number for their Tech dept. The one listed no one answers. Because this is a big deal and as I said it was the reason I purchased their WiFi 6 router. The router is quite expensive and it has been well over 7 months with this problem not being able to use WiFi 6. They said that the Orbi RBR850 was backward compatible and it certainly is not. Thanks again. Hopefully someone will be able to provide me with a working number for their Corporate Offices.
Rottikid
- CrimpOnJan 17, 2022Guru - Experienced UserWiFi5 uses the 5Ghz frequency. 6G is WiFi6E
The 850 does not support 6G frequencies (WiFi6E) only the newest product supports 6G frequencies- RottikidJan 17, 2022GuideI am not talking about WiFi6E. I am talking about WiFi 6. Tri-band Mesh WiFi 6 system that requires WPA3 Security Protocol. The RBR850 does support WPA2 /WPA3 which is necessary for WiFi 6 to work with older 2.4 & 5 g You are mistaken. Your talking about Orbi’s 960 series which is Quad Band and WiFi 6E.
- FURRYe38Jan 17, 2022Guru - Experienced User
Ok, Lets get something right here, WiFI6 = AX mode on 5Ghz. Its does NOT require WPA3 whatsoever. AX mode works with WPA2 and AES only. 5Ghz and AX mode as been working with WPA2 and AES for past 3 years. I've been using 5Ghz AX and WPA2 and AES on Orbi 8 series since 2019.
WiFI6E is 6Ghz freqency which also uses AX mode on 6Ghz. This does require WPA3 I believe.
Early ON, Orbi AX system supported mixed mode WPA2 and WPA3. However it was found that there were core problems with the WPA3 handling with devices. So NG removed the MIXED MODE from the Orbi UI. NG left the WPA2 only or WPA3 only settings in the UI. WPA3 still has limited support and use on mostly seen on newer generation supporting devices. NG will need to re-implement Mixed Mode WPA in the UI once the WPA community has fixed the core code and is stable to use in Mixed Mode.
Hopefully NG will at some point as I can attest that with my 9 series Orbi, Mixed Mode is working.
