TheTiz
Feb 10, 2022Aspirant
Orbi Router R850 router gives woefully slow Wi-Fi speeds, but when hardwired delivers blazing speeds
I have had the 750 before the 850 and had the same issues. I have talked to at least 10 different techs and made all kind of adjustments to the settings, but nothing works. My modem is provided by ...
- Feb 13, 2022
Hmmm... tech said it was a sagecom and that it was just a modem. After 5 days from the purchase and installation the speeds are starting to increase, especially in the early morning hours. the room that is further away from the router is getting the strongest wifi signal( consistently in the mid 400s mps) the satellite is 15 feet away. The satellite is roughly 30 feet away from the router, in view of the router.
TIA for all yor input and help
Tiz
Feb 10, 2022Guru - Experienced User
What wifi devices do you have connected and speed testing with?
TheTiz
Thank you. I will give requested info when I get home
