TheTiz
Feb 10, 2022Aspirant
Orbi Router R850 router gives woefully slow Wi-Fi speeds, but when hardwired delivers blazing speeds
I have had the 750 before the 850 and had the same issues. I have talked to at least 10 different techs and made all kind of adjustments to the settings, but nothing works. My modem is provided by ...
- Feb 13, 2022
Hmmm... tech said it was a sagecom and that it was just a modem. After 5 days from the purchase and installation the speeds are starting to increase, especially in the early morning hours. the room that is further away from the router is getting the strongest wifi signal( consistently in the mid 400s mps) the satellite is 15 feet away. The satellite is roughly 30 feet away from the router, in view of the router.
TIA for all yor input and help
Tiz
Feb 11, 2022Guru - Experienced User
If you mean Sagecom, these branded modem usually have a built in router and Wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
TheTiz wrote:
Firmware:vr.6.3.16
modem: spectrum/ stagecom
TheTiz
Feb 13, 2022Aspirant
Tiz
- FURRYe38Feb 13, 2022Guru - Experienced User
Enjoy. 📡
