kyle_mzanzi
Nov 01, 2022Aspirant
orbi router rbr350 setup
Hello Team, I am hoping someone could help me with setting up my orbi? I got it as a present for my father who is a network engineer/architect and he had some trouble setting up his orbi. so I took ...
Nov 02, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Recommend using a PC and web browser connected to 192.168.1.1 to setup the RBR and system.
kyle_mzanzi
Dec 14, 2022Aspirant
Hey furry,
The Orbi Firmware Version is V4.20.0.4_3.100.71
Not sure what the mfr but the model of the isp modem is Spark smart modem VRV9517UWAC34-A-SP
The ont is just a standard chorus ont
see pictures attached for the routers and ont.
i have tried setting it up on a web browser however theres not much that can be done, i think i would be better off maybe buying a deco
- FURRYe38Dec 16, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
