redsfanwente
Jul 24, 2022Follower
Orbi Router RBR750 and Satellite RBS350 - Satellites Constantly Rebooting
I tried to update the firmware for the router, and was successfully able to do so to 4.6.8.5. However, when I tried to update the satellites, the webpage asked for a username and password.So, the sa...
Jul 25, 2022Guru - Experienced User
Be sure to remember to update the RBS first then the RBR lastly.
If you can't get the RBS updated or access them, you may need to downgrade the RBR back to v.2 then update the RBS after they get re-connected. Then update the RBR lastly.
redsfanwente wrote:
I tried to update the firmware for the router, and was successfully able to do so to 4.6.8.5. However, when I tried to update the satellites, the webpage asked for a username and password.So, the satellites are on 4.6.8.2.
It was recommended to upgrade the firmware because the satellites are constantly "rebooting" (blinking white light then to solid blue). They do this multiple times an hour, and usually drop service as well. They are not going to the purple color. They are always going back to blue.
Any suggestions?
