peter67
Mar 06, 2025Follower
orbi router RBR750
I believe I have to do a hard reset on my device. My question is will I lose the ability to connect all of my other devices that have already been set up. Will I have to connect each device again one...
Mar 06, 2025Guru - Experienced User
IF you factory reset the RBR and setup from scratch and use same SSID name and password for the wifi, your devices will auto re-connect.
