peter67
Mar 06, 2025Follower
orbi router RBR750
I believe I have to do a hard reset on my device. My question is will I lose the ability to connect all of my other devices that have already been set up. Will I have to connect each device again one...
Mar 27, 2025Guru - Experienced User
Any progress on this?
peter67 wrote:
I believe I have to do a hard reset on my device. My question is will I lose the ability to connect all of my other devices that have already been set up. Will I have to connect each device again one by one ? The reason why I have to do a reset is because I can not update the firmware. I am not able to get into the app to control any of the satellites. I never set up an admin password because this is just for home use. Somehow I need the admin password to get in. Security questions that I need to answer are not the correct ones. So what is the best advice to get this cleared up. Thanks
Peter
