javierfalcon
Sep 30, 2022Aspirant
Orbi router RBR850 does not accept 2.4 connections only satellite
Hello, I have a RBR850 router (3nd floor in a townhome) and one satellite (RBS850) in the 1st floor. I notice that 2.4 devices only connect to the satellite, regardless the distance including tho...
CrimpOn
Sep 30, 2022Guru - Experienced User
During this time, were any of the WiFi devices powered off and back on again?
- javierfalconSep 30, 2022Aspirant
Hi,
I only tried rebooting a couple of devices (iDevice AC switches) and remained "alarmed".
- FURRYe38Oct 02, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
- javierfalconOct 20, 2022Aspirant
Excuse the delay to respond but I had not been able to try any troubleshooting steps. Finally today I was able to do some testing and I really doubt that it has to be with distance from Satellite to Router or the modem. The reason why I said this is because andI set the router to factory settings and decided to install just the router with no satellite. Hence when prompted for number of satellites attached during the setup process, I indicated that there was not satellite and left only the router configured as standalone.
As soon as configuration was complete I noticed that only 5ghz devices were connected I tried with one of my 2.4 idevices switches set it to factory default and tried to connect it to the network and no luck, it never got connected. I left the router connected for about one hours and no 2.4 devices were able to connect. Then I decided to install the satellite and guess what right away the 2.4 ghz devices started to connect. I begin to think that the router has an issue with 2.4 connections.
Current firmware installed: V4.6.9.11_2.3.5
