shareece
May 13, 2024Aspirant
ORBI ROUTER RBRE960 RANGE SUDDENLY DIMINISHED
I have had the Orbi mesh system for 15 months. All has been working fine until now. All of a sudden, I have a dead zone nearby the router in my living room. I have high internet speed while standi...
May 13, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What devices do you have connected and testing with?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter and IPv6.
- shareeceMay 13, 2024Aspirant
Thank you. I will look into all of this.
