DNielsen
Jan 15, 2022Aspirant
Orbi Satelit loosing connection - Ethernet Backhaul connected
Just got a RBR750 and RBS750. The RBR in the main house works fine. But I seems to have issues with the RBS750, which is in the workshop. They are backhaul connected via ethernet cable. Fro...
- Jan 15, 2022
what version of the firmware is the router/satellite on?
there's a beta version that just released that had a lot of fixes.
Jan 15, 2022Guru - Experienced User
Are the RBS directly connected to the RBR or is there a LAN switch in betwen?
DNielsen wrote:
Just got a RBR750 and RBS750. The RBR in the main house works fine. But I seems to have issues with the RBS750, which is in the workshop.They are backhaul connected via ethernet cable.From time to time, it just drops the connection (Every 10-15 minutes). I'm perfectly connected to the sattelite (which I can ping) but I cannot ping the main router, while its lost:Reply from 192.168.1.1: bytes=32 time=3ms TTL=64Request timed out.Request timed out.Request timed out.Request timed out.Request timed out.Reply from 192.168.1.1: bytes=32 time=3ms TTL=64Reply from 192.168.1.1: bytes=32 time=3ms TTL=64But no problem pinging the satelite:Reply from 192.168.1.4: bytes=32 time=2ms TTL=64Reply from 192.168.1.4: bytes=32 time=2ms TTL=64Reply from 192.168.1.4: bytes=32 time=2ms TTL=64Reply from 192.168.1.4: bytes=32 time=10ms TTL=64Both computers does it, the desktop where I got a ASUS AX58BT WiFi 6 card, and my laptop; MSI with Intel Wireless card.The app says there is connection between the router and satelitte.The ethernet cable works without any flaws with other routers.Any ideas? What am I doing wrong?
DNielsen
Jan 16, 2022Aspirant
Directly, no switch in between.
