DNielsen
Jan 15, 2022Aspirant
Orbi Satelit loosing connection - Ethernet Backhaul connected
Just got a RBR750 and RBS750. The RBR in the main house works fine. But I seems to have issues with the RBS750, which is in the workshop. They are backhaul connected via ethernet cable. Fro...
- Jan 15, 2022
what version of the firmware is the router/satellite on?
there's a beta version that just released that had a lot of fixes.
Jan 15, 2022Guru - Experienced User
DNielsen
Jan 16, 2022Aspirant
So far, a couple of hours in, and haven't seen a dropout since, fantastic, thanks! :-)
- FURRYe38Jan 16, 2022Guru - Experienced User
Just curious, did you power cycle the RBR and RBS after applying the v5 FW or was a reset performed and setup from scratch or just applied the FW and continued with out interrption?
