fxbeet15
Aug 15, 2023Follower
Orbi Satellite connected to Ethernet and showing up in orbilogin menu but no internet
Hi all, the header pretty much sums it up - my router is working fine, my wifi is fine, and the satellite shows up as "wired, connected, backhaul good" but it wont show up when I am trying to connect to wifi standing next to it. Any suggestions welcome! Thank you!
1 Reply
What model Orbi do you have?
How is the RBS ethernet connected to the back of the RBR? Directly to the back or is there a ethernet patch panel or a LAN switch in between? https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
What CAT# lan cable are you using between the RBR and RBS? CAT6 is recommended.
Wirelessly connect the RBS to the RBR. Does a wireless device get internet services then?
