Darrelltate
Oct 13, 2020Aspirant
Orbi satellite daisy chain via switch
Wondering if I can connect two orbi satellites via Ethernet through a switch. 1st satellite is connected via wifi to router. This satellite is connected to a switch via Ethernet. Wondering ...
- Oct 13, 2020
Yes, that is exactly how mine is set up. 2 x wired, 1 x wireless. Just make sure your switch is not "green"
Darrelltate
Oct 18, 2020Aspirant
Thank you!!
it occurred to me that I could just connect satellites via Ethernet cable and then connect the switch to the second satellite.
thanks again for taking the time to reply.
Oct 18, 2020Guru - Experienced User
You can do that too.
Enjoy. :smileywink:
