N4cE
Jan 26, 2022Guide
Orbi satellite disable 2.4g automatically
Hi all, I have a set of orbi RBK353 in my house. Someday I found all my IOT with 2.4g equipment are connected to my main router instead of the nearest satellite. So some of my IOT equipment got weak...
- Feb 12, 2022
Hello!
Didn't set the 2.4G transmission below 100%?
I also had this problem, but with this setting ok:
Jan 27, 2022Guru - Experienced User
what firmware is on the router and the satellites?
Did you try a simple factory reset on the satellites and re-synce?
N4cE
Jan 27, 2022Guide
plemans wrote:what firmware is on the router and the satellites?
RBR350(router):V4.4.0.10_2.10.63
RBS350(satellites):V4.4.0.10
No, I have not trying a factory reset. Does it helpful? Maybe I can try this!
By the way, all satellites are connected to router by ethernet cable.
- plemansJan 27, 2022Guru - Experienced User
It can be a quick fix sometimes.
- ekhalilJan 30, 2022MasterIt can be that the satellite is seeing too much disturbances on the 2.4 GHz band and is therefore blocking it?
Are you using “Auto” in your 2.4GHz channel selection settings? Please try changing to a fixed channel. Select a channel that isn’t being used in the area.
If you already use a fixed channel then please try to change to another channel and see if this will solve the issue.- N4cEFeb 06, 2022Guide
If you already use a fixed channel then please try to change to another channel and see if this will solve the issue.Yes, I tried channel 2,6 and 11 of 2.4g but it's still turns into disable for a while.
