N4cE
Jan 26, 2022Guide
Orbi satellite disable 2.4g automatically
Hi all, I have a set of orbi RBK353 in my house. Someday I found all my IOT with 2.4g equipment are connected to my main router instead of the nearest satellite. So some of my IOT equipment got weak...
- Feb 12, 2022
Hello!
Didn't set the 2.4G transmission below 100%?
I also had this problem, but with this setting ok:
Jan 27, 2022Guru - Experienced User
what firmware is on the router and the satellites?
Did you try a simple factory reset on the satellites and re-synce?
Kunson
Feb 11, 2022Aspirant
firmware version display in image and posted on message.
And yes. I did tried factory reset and resync it totally not working!!!
Thanks.
