N4cE
Jan 26, 2022Guide
Orbi satellite disable 2.4g automatically
Hi all, I have a set of orbi RBK353 in my house. Someday I found all my IOT with 2.4g equipment are connected to my main router instead of the nearest satellite. So some of my IOT equipment got weak...
- Feb 12, 2022
Hello!
Didn't set the 2.4G transmission below 100%?
I also had this problem, but with this setting ok:
mllrgy
Feb 12, 2022Initiate
Hello!
- GroundGioFeb 13, 2022Guide
mllrgy: I am trying out this setting now, but is Hong Kong location really where you live, or just part of your proposed solution?
- mllrgyFeb 13, 2022Initiate
i live in Europe :smileyhappy:
- N4cEFeb 13, 2022Guide
mllrgy wrote:Hello!
I am trying to uncheck 20/40 MHz coexistence now. I can't revise my region, it's NA now.
- N4cEFeb 16, 2022Guide
Update:
Today is my 3rd day after unchecking the 20/40 Mhz coexistance(I only change this one).
My 2.4g is still online! I will keep monitor if it's working normally and feedback to this thread.
Thanks to everyone!
N4cE wrote:
mllrgy wrote:Hello!
- FURRYe38Feb 16, 2022Guru - Experienced User
