N4cE
Jan 26, 2022Guide
Orbi satellite disable 2.4g automatically
Hi all, I have a set of orbi RBK353 in my house. Someday I found all my IOT with 2.4g equipment are connected to my main router instead of the nearest satellite. So some of my IOT equipment got weak...
- Feb 12, 2022
Hello!
Didn't set the 2.4G transmission below 100%?
I also had this problem, but with this setting ok:
GroundGio
Feb 15, 2022Guide
I received an answer from NG support (but no new FW version):
They advise to change the the 2.4 GHz channel (Basic- Wireless - Channel)
And also change settings via Advanced - Advanced settings - Wireless settings:
2.4GHz:
- Uncheck the 20/40 Mhz coexistance
- Preambule modus : Long
5 GHz:
- Preamble modus: Long
I haven't tried out these settings yet because I did a factory reset on the router 2 days ago and reconfigured it from scratch (no back -up file)
That immediately resolved my issue with the RTSP port forwarding (port 554). And also the 2.4 GHz network has not went down since.
So I will keep everything as it is for the moment.
Feb 15, 2022Guru - Experienced User
Thanks for letting us know this. Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
2.4GHz:
5 GHz:
