Bordigles
May 26, 2023Tutor
Orbi Satellite disconnets when streaming video
 I have an RBR350 with four RBS350 satellites. My LG TV is connected by RJ45 to one of these Satellites which in turn has a wired connection to the Router via a switch. When streaming videos from my S...
- May 26, 2023
Have you tried changing what channel you're using for the 2.4ghz and 5ghz?
the 350 series is only dual band so is a bit more sensitive to interference/high bandwidth than the tribands.
Bordigles
May 26, 2023Tutor
Thanks for your reply
Sorry, I have given the wrong config.
The satellite is not connected to the router by copper, only wireless. See attached image map
May 26, 2023Guru - Experienced User
- BordiglesMay 26, 2023Tutor
I'll try that thanks. It was set to auto, I'll try one of the higher DFS channels, they look pretty clear in my location.
Andy
