terra_orbi
Jan 18, 2024Aspirant
ORBI Satellite in Wired Connection
Hello, I have one ORBI RBR 850, two Satellites ORBI RBS 850 and one Satellite IRBI RBS 750. The Satellites are connecting. One of my ORBI RBS 850 used the wired connection. As a matter of fac...
Jan 19, 2024Guru - Experienced User
If the RBS750 is wanting to wirelessly sync to the RBR and not use the ethernet connection thru the Airbridge path, this means this path is not working correctly for the ethernet to the RBS to work right. Something on this path is blocking good traffic flow between the RBR and RBS. So the RBS will revert to wirelessly connecting. Something even if you could force it, would not work since something in the path is blocking or not working right.
Test this out by connecting the RBS750 directly to the back of the RBR850 and see if it connects wired there.
Be sure FW version on the 750 is same as what's loaded on the rest of the system.
