Jeffoz
Dec 23, 2019Apprentice
Orbi Satellite issue
Hi, I just installed my Orbi AX. Setup is as following. - Fiber router/modem from provider in the power closet/shelf downstairs. DHCP on here so serves as router. Not easy to disable router functi...
- Dec 26, 2019
Yes. The RBR needs direct connnection to the RBR and not thru a different router. You can have LAN switches in between the RBR and RBS, however it can't be a different router. Even in AP mode, the RBS needs to be directly connected to the RBR.
I noticed this as well after connecting up my system in AP mode with a XR450. I had the RBS connected to the back of the XR router and the RBR also connected. The RBS would not sync correctly until I moved the LAN cable from the XR router to behind the RBR. Then the RBS came to ready correctly.
Jeffoz
So basically what I wanted is use both the router and satellite as wired AP's. Then later use the wireless backhaul for the 3rd floor as I have to cabling there, for a 2nd satellite.
But right now because the Satellite when you connect it wired it will not be seen as such by the software it's a bit of a pointless device. Like any other device, tv, DVD player or whatever. It just can't pair when wired. Straight when I take the wires off it pairs fine.
This must be the software, there is also no way to login to the Satellite and set it as wired AP or something?
