bpalob
Mar 30, 2021Tutor
Orbi Satellite permanently pinging the gateway
 First of all, I am using the Orbi RBR750 system, which I didn´t find in the Model Listing for this forum.      The FW in use is V3.2.16.22_1.4.9.     I found a thread about the same issue, which seem...
Mar 30, 2021Guru - Experienced User
I would presume so as there is a status report and detection happening with in the system and maintaining the connection between the units. If something happens then the status changes and thus the front LED will give indication of this. All this and other things rely on this design. Something to ask NG support about for more information.
