bpalob
Mar 30, 2021Tutor
Orbi Satellite permanently pinging the gateway
 First of all, I am using the Orbi RBR750 system, which I didn´t find in the Model Listing for this forum.      The FW in use is V3.2.16.22_1.4.9.     I found a thread about the same issue, which seem...
Bingoig11
Mar 30, 2021Star
Have this kind of issue with the Mesh Nighthawk, except that the satellite is pinging a netgear website every second...
Case opened with Netgear, abnormal behaviour, waiting for a new firmware to be published (no ETA).
Mar 30, 2021Guru - Experienced User
What FW are you using?
Bingoig11 wrote:Have this kind of issue with the Mesh Nighthawk, except that the satellite is pinging a netgear website every second...
- Bingoig11Mar 30, 2021Star
FW version is V1.0.6.110_2.0.49
Netgear support closed the case saying that the issue is identified and should be resolved in the next firmware.
- FURRYe38Mar 30, 2021Guru - Experienced User
What model Orbi do you have?
Bingoig11 wrote:FW version is V1.0.6.110_2.0.49
As stated in my first reply, I'm facing similar issue with the Mesh Nighthawk system, not Orbi :)
