Deepak_Mehta
Aug 18, 2022Aspirant
Orbi Satellite RBR850 doesnt connect
I facing a big problem, i have installed 1 Orbi router and 5 satellite RBR850 in an 3 storey house, and placed the devices floor wise ( some in rooms couple of them in bedroom and living rooms) at sp...
Aug 19, 2022Guru - Experienced User
Deepak_Mehta wrote:
I have changed power output to 50%
So you have RBS that are wireless connected and some wire connected? Yes
Ethernet are connected RBS via Cisco unmanged switch which is between the RBR and RBS? <What is the model# of this switch?
Yes i am using CAT6
I am using 48 on 5Ghz. and 6 on 2.4Ghz.
There are 2-3 wifi neigbhors with very very weak signal
CTS values is kept on automatic <CTS values should read a number and not automatic
Will try to keep off couple of devices.
Sharing a snapshot of devices.
Deepak_Mehta
Aug 20, 2022Aspirant
As details were discussed in above post i have done all the settings as you told me, still same issue is there,
Devices gets disconnect and reconnect after sometimes and this happens all the time.
Is there any other solution to find out and rectify this issue.
