windyfinch225
Nov 22, 2023Tutor
Orbi Satellite RBS750 Dissasembly
My RBS750 satellite was knocked off its wall stand and the Brass "nuts" located in the unit used to screw it into the stand have dislodged and are floating around within the unit. How do I disassembl...
CrimpOn
Nov 23, 2023Guru - Experienced User
Thanks for finding the FCC information on the RBR750. I still can't make any sense of "where to start".
I usually start with a screwdriver 🙂
- CrimpOnNov 23, 2023Guru - Experienced User
Exactly. Have screwdriver in hand, but cannot find any screws! On the original Orbi, Netgear hid the screws behind the Ethernet port label (WAN, LAN, Power, Sync, Etc.) The key was to peel off the label and expose the screws.
On the 750, it appears that there are two "tabs" that engage somehow and magically hold the back on. The FCC picture shows the cover piece sideways and it looks bigger than the case. (optical perspective perhaps?)
There are videos on the internet for everything under the sun except opening this case!
