windyfinch225
Nov 22, 2023Tutor
Orbi Satellite RBS750 Dissasembly
My RBS750 satellite was knocked off its wall stand and the Brass "nuts" located in the unit used to screw it into the stand have dislodged and are floating around within the unit. How do I disassembl...
Nov 22, 2023Guru - Experienced User
Might check under the rubber footing at the bottom to see if there is any hidden screws there.
windyfinch225
Jan 12, 2024Tutor
No visible screws under the rubber footing. Nothing under the sticker on the underside of the unit that lists model and serial either.
