windyfinch225
Nov 22, 2023Tutor
Orbi Satellite RBS750 Dissasembly
My RBS750 satellite was knocked off its wall stand and the Brass "nuts" located in the unit used to screw it into the stand have dislodged and are floating around within the unit. How do I disassembl...
CrimpOn
Sep 07, 2025Guru - Experienced User
The RBR750 is similar to other Orbi routers. The screws which must be removed to open the case are hidden behind the label around the Ethernet ports. This guide explains the process for opening the case:
