Newt8456
Jun 26, 2024Follower
Orbi Satellite RBS850
Hello, we have had the Orbi Satellite RBS850 in my house for about two years now and until recently it has worked great. Two weeks ago the Orbi started acting up, back then it was nothing simply shu...
Jun 26, 2024Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does swapping RBS locations with another follow the problem or remains at same location?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
